HELP
shiftsuper175607
THAT IS MY MOWER EXACTLY , WHERE IS THAT PART THAT WILL TIGHTEN UP THE BELTS, AND YES THEY ARE BOTH LOOSE , THE ONE IN THE FRONT MORE SO THEN THE OTHER ?
AND THANK YOU IN ADVANCE FOR YOUR TROUBLE !!
If you enter the model and serial in the link provided you can see what it says about the belts.
If you also provide the numbers in a post there may be others who can help.
https://www.cubcadet.com/equipment/cubcadet/operators-manuals
shiftsuper175607
You have a drive shaft...I am not familiar with those...
Here is a link to a service manual...very complicated information...
Look about middle of page and see Garden Tractors
top one on left side is 3000 series tractors
this is a pdf service manual for your tractor.
https://www.cubcadetpartsnmore.com/cub-cadet-service-manuals
MYTMERLIN
THE ON;Y NUMBERS I COULD FIND WERE ON A PLATE ON THE ENGINE
MODEL -350447
TYPE - 1206E1
4952
CODE - 97111811
shiftsuper175607
Something I thought of...There is a brake lever somewhere?
I am assuming it is on....take it off and see if either belt tightens.
I would not think that your tractor would not move at all if the belt is not getting tight.
MYTMERLIN
I AM 70 YEARS OLD AND DISABLED
I HAVE A CUB HDS 3185
WHEN THE MOWER STARTS AND YOU ENGAGE THE BLADES IT TAKES ABOUT 10 OR 15 SECONDS FOR THEM TO START, THEY DON'T TURN FAST ENOUGH TO CUT AND THE ENGINE CUTS OUT ?
The two belts on the front of mower , need replacing , how do I do that ? It is a HDS1385
