Okay, so I was asked to work on a riding lawn mower. Originally I was told it just needed a new battery because it wouldn't start and the battery wouldn't hold a charge. I replaced the battery and still no start. I used a multimeter to trace the power from the battery to the ignition switch to the safety switch and then to the condenser solenoid. On the solenoid there are 3 wires. 1 wire from the battery, 1 line from the ignition switch, and 1 line from the solenoid to the starter. I got 12.60V to power terminal, 12.60V to the terminal from the ignition switch when I turn the key. I don't get anything coming out of the terminal that goes to the starter. I figured bad solenoid so I replaced it but same thing. No power coming out of the solenoid but power going in. I can hot wire it by bridging both the power in terminal and the power out terminal and it starts right up so I know everything after the solenoid works. I'm stumped why a brand new solenoid won't have any power coming out of it. I don't think it's the ground because it grounds to the body and I cleaned that up before installing the new solenoid. When it still didn't work I wired up a ground to see if it was the ground and it still wouldn't work.
Does anyone have any idea what my problem is? I don't know what could be wrong with a brand new solenoid. I've hit a dead end.
