NativeGardener
- Oct 2, 2023
- 1
- 1
Ok, longtime listener, first time caller here...
I have a 3 year old Craftsman T210 with the Kohler 5400 series engine - 18HP 541CC. Here's the high level:
Thanks for all advice/help!
- It is running ROUGH (sputters, not much power particularly when the blades are engaged)
- hard to turn over - even replaced the battery, which helped a little, but turns a lot before it engages
- can't have the throttle all the way up to "rabbit" setting (it chokes up at that level vs revving high like when it was new), I have to leave it about 2/3 up
- replaced the oil, oil filter, and the air filter - no improvement
