Are you sure you didn't switch the heads around, there is a cylinder #1 and #2. You must install the heads on the correct cylinder.
I thought about that to Rivets, but also thought that if they were on the wrong side the exhaust and intake ports would be upside down.
He has a compression problem. I have considered the timing is incorrect and the valves are opening and closing at the wrong time. but without the pushrods in place he should have compression, unless the fact the intake valve isn't opening and can draw in air there is nothing to compress.
I think if it was mine I would try a leakdown test and make sure there isn't a ring problem or some other problem causing lack of compression. After that I would be rechecking the camshaft timing.
