85mudslinger
- Jun 16, 2014
- 1
- 3
checked few other forums. threw out this pick up. i have done a lot to my cub cadet 1641 v-twin, anyway the current problem is engine surging/hunting... messing with the choke does not seem to help my cituation.. but if i put it about 3/4 throttle it seems to run fine... any other time its running so poorly id almost think its running on one cylinder.... i check the spark plugs there fine except a little red/brownish colored which they was brand new just yesterday... i have already tried readjusting the mixture screw and idle screw. so ive been thinking between a governor issue or trying to clean the carburetor.... any idea's or opinion's? everything ive heard that has to do with bad idle like this usualy you can fix it by playing with the choke... so that's why im wandering if its not the carb.. maybe its the governor assymbly.. considering when its more throttle its putting more pressure on governor springs making them tighter i think....
