Help with identification?
TamStem69
I have been trying to identify my mower and have came up with model 7271 but would like to know if I'm even close. The model number tag is blank. I changed the plastic wheels years ago for the steel now on it and added a push button kill switch as well. The flywheel brake is tied down in the photos while I work on it. Runs great but needs carburetor gaskets. TIA!
Most likely it will have a 684352 carb on it. Those engines were used on many different Lawn Boy models and parts are readily available through a Toro dealer. Try Lawn Boy model 5254 and see if the parts look familiar.
TamStem69
You pointed me in the right direction. The 5254 has the throttle control on the handle bar where mine has a fast and slow above the air filter. I checked the 5253 and I think I have that model. Thanks for the reply. Appreciated.
