Russ2251 Well-Known Member May 31, 2018 #11 Moisture in the coil could explain what's happening -- as "baking" it in the sun resolves it. Click to expand... Russ sees all, knows all. Check for cracks in epoxy.
D darcyh Forum Newbie Jul 1, 2019 #12 I'd bet it's the coil too. You can purchase non OEM replacements quite inexpensively on Amazon etc. Did you solve this yet?
