Hi need help troubleshooting this issue Duraforce Silverpro 10247:
Issue: Won't initial start 95% of the time . when outside temp is cold or hot -- makes no difference -- it doesn't start after I wheel it out of shed. The ONLY way I can make it start is leave it IN THE SUN on a hot day for a couple of hours, then it starts with one pull. Also after it does start, It will perform like a wonderful, amazing beast. I CAN restart with one pull after that within a few hours after the initial start.
Done so far but issue persists:
Cleaned carb. It is spotless and all injector holes are open. Cleaned airfilter. Spark plug is new (last year) but have not checked it. Problem was there with old sparkplug too. cleaned exhaust muffler (bottom) under the blade. Fuel line is clear. fuel flows out nicely out of line. Cap plug hole is clean. New fuel and carefully measured new fuel mixture.
What can be affected by sunlight and heat? and why would the machine be perfect after the first start? what can I check?
Thanks in advance for replies.
