fosterrrrr
- Aug 10, 2019
- 2
OK, so this was basically my first mowing experience in over a decade. Pardon me if my vocabulary is not correct, hopefully the pictures will help explain. So about two minutes into mowing, the bar that you hook the grass bag to came unattached on the right side. I took the bar out and a spring came off as well. Does anyone know where I should put this spring and if I should be looking for another part?
https://i.imgur.com/3i9HdmF.jpg
https://i.imgur.com/C3IuPhe.jpg
https://i.imgur.com/rGIMlvM.jpg
Edit: so I'm pretty sure the spring goes here and fits into that opening on the left side. https://i.imgur.com/XmguC2D.jpg
But it still won't remain attached. Should there be an attachment/bolt on the right side of the bar like you see on the left side? I wonder if that came off?
