Help with Briggs vanguard 28 efi
trush
Looking for help changed ignition switch on briggs 28efi on a scag mower believe I put the wrong one in at first now I have the right one in and I don’t hear the fuel pump noise when putting key in run position?? Checked fuses 1 was blown on the scag harness & I replaced but still no fuel pump noise Engine cranks slowly
It would help to the engine and equipment numbers so we could look the wiring. Personally I am not a stable genius with all seeing crystal ball. It just cracked up over someone getting a radar controller module in place of set of piston rings.
trush
Model 490000 810cc vanguard efi
49e877. 000501. 150204yf
Appears that your engine is 49E877-0005-G1
Briggs Twin EFI SM
If turns out to the control module you need to take it to a Briggs dealer so they program the new module.
