If you look below the clutch pedal area under on the deck there is a few brackets for the rear lift. You might have lost a clip and a pin might have slipped out.
Hi Timtractor,
Thanks for the advise. I checked out the back of the deck and sure enough the parts that hold up the back was missing. The carter pin had come off and all 5 pieces were gone... i have replaced them and im back to mowing... I appreciate your help...
