Help needed
Terry Michaelis
I need help my lawnboy platinum is getting no spark looks like a clear switch under the flywheel has a paperclip size trigger that is moved by kill bale. however it does not open the circuit. No matter the position it still grounds out the coil. this is a 10785 270001254. without the ground out wire the mower mows great the grass catcher kill system works as designed. Someone please help me tlmichaelis48@gmail.com
