Help needed
Yes we might be as you know as well as me that things must troubleshooted down to the cause before we can say what it is exactly. Sometimes it is the simplest thing that can be the problem and other it is something major.
VRR.DYNDNS>BIZ
I seldom have to revert to blind replacement. As advised, buy the manual. Do some diagnostics, symptoms tell us many possible factors, diagnostics traces root cause and until root cause is found or fixed, no solution will happen and blind replacement may aggravate or cause more problems.
