Need help bad, my dads mower leaked hyd fluid from a bypass hose on top of the transmission,i replaced the hose,and the fan that cools the hydro trans,(blades broken) any way before i changed the hose,and the blade even with the leak the mower worked, took it back he mowed about 5 mins and the blades stopped,it has a shaft for the blades,and the drive for the wheels,when you put the arm in gear for the mower part the blades dont move, you can remove the drive shaft from the mower deck and put it in gear and the splines turn,you can stop it with your hand, so my question is , with a hydro sysem and been low on fluid,where do i bleed the air out of the system ? every thing works but the blades, it drives fine,the deck lift up fine the steering is fine but no blade engagement
Thanks very much for the help my Dad is 88 years old and i would like to get this fixed he likes doing yard work !
this is my first post here so be gental ...
you can also email me at roytotherescue@yahoo.com
