Here is the issue.
The engine is a Tecumseh TMV125 on a really old Craftsman rider. I have been looking at the Tecumseh tech manual I found on here and it looks like a series 1 carb. Here is the thread I started with a pic of the mower. http://www.lawnmowerforum.com/small-engine-mower-repair/3345-sears-rear-engine-rider.html
The mower will not start unless I have the gas cap totally off not just loose I have to have it off completely.
If I take the cap off, put on the choke, a pull it will start then I need to quickly take off the choke and put the cap on or it will not stay running. It doesn't matter if the engine is hot or cold. The level of gas in the tank doesn't matter.
So far I have replaced the air filter, the gas cap, and ran a tank through it with some carb cleaning stuff. What should I try next?
