help Hrr
Honda hrr vxa won't start it start with starting fluid and it's die just put a new carb. new spark plug
Double check all gaskets, spacers, insulator, air guide, etc. If you get one on wrong or flipped around, it will never start. Confirm the choke is working properly.
If you'll share the serial number off the back of the mower with me, I can get you exact drawings and steps
; here is one for newer HRR216VXA models with Autochoke:
