Short version: Toro 36" walk behind, proline with the cv13t command pro pull start. It hasn't run in 5 or 6 years. After a few pulls, it will start for a few seconds and quit.
Got this mower at an auction from a place where it was used non-commericially as a maintenance mower for a couple acre property. They used it for a year or two then bought new and this mower set for 5 to 6 years. I know that doesn't make any sense, but it was government owned and so that should explain why they would do something so nonsensical.
Anyways, I picked it up and the pull start was very hard to pull. After I took the top cover off, what was causing the friction was the little electrical connections that I presume make the spark plug spark. I adjusted it so that it wasn't rubbing so hard, thought it still touches. Are these electrical connections on the flywheel actual supposed to touch?
I then drained the gas from the line at the carb, and refilled with good gas. The oil looked good, a little above "full" but not too dirty. I figured I'd get it to run then change the oil. Put a new plug in and attempted to start. It started for a few seconds after a few pulls, then die. Then wouldn't start again for another 8 or so pulls, then again stay started for only few seconds.
The next day I emptied the carb bowl since there was still bad gas in there. There was some flakey deposits floating around. Let the bowl fill up with good gas and tried to start again. It would only stay started for a few seconds then die again, just like the day before.
Am I making a stupid mistake and not taking it off "choke" right after it starts or something? Not sure why it dies so quickly. Any thoughts???
Thanks!
