Snapperfreak
- Dec 13, 2011
- 22
- 676
Thank you, but I must say after tearing down a couple of mowers and going thru all the work of that and sanding and priming and painting and reassembling, I prefer them in their original finish. They have more character with their untouched patina. A good cleaning is all I do now and your mower is in pretty nice shape just how it is. You're cleaning paid off well. I doubt I'll ever disassemble and repaint another snapper, but I have lots of simple green, cleaning towels and brushes.
Ok, as for your throttle, it does appear correct from what I can see. I'm not much of a mechanic unfortunately, but try unbolting the throttle cable from the side of the engine, while it's on choke, and see if u can move the cable any farther foreword. If so, keep it there and bolt it back up. That should insure that the choke is engaged when it should be. As for the coil, I'm sorry but I don't have any experience with that. I can say that's a very nice snapper and I know it's in good hands.
