The large brass drain at the base of the motor ,carb side.Loosen the drain slightly just to break free,slide a pc of clear 3/4 in. ID tubing about 6 or 8 in. long over the front round part of the drain,then back off the drain slowly until the oil starts flowing thru the tubing into a recepticle.
