Help!!! 2015 Hustler Raptor no hydraulics
Tim6559
Hey guys! I have a 2015 Hustler Raptor, 60" with about 350 hrs. While mowing today all the the sudden I lost all hydraulics. A quick glance showed that the hydro belt had popped off. No big deal, popped her right back on (yes its routed correctly), and to my surprise, still no hydraulics. I have no idea where to look next. Note: both pulleys on both motors are spinning full speed, but the belt is vibrating like crazy...dont know if that has anything to do with it. Any advice would be appreciated.
hlw49
Check the trans mounting brackets they are having an issue with the brackets breaking. Trans belts don't jump off for no reason.
MParr
Have you checked the tension spring and the clutch mounting bracket?
