Hi,
I'm new here. To introduce myself - We live in Aix en Provence in the south of France where i recently retired after working on nuclear fusion in the worlds larges fusion reactor project. We have a house with 5 acres, but probable 3 of those are forest. A large portion consists of an olive grove with 100 trees and very bumpy grass underneath. I have a 2001 John Deere LTR 166 mower.
i will try to post my first serious problem in the appropriate section - if i can find it
hoping to hear from you,
Michael (aka pick2610)
my problemi is that i started the new mowing season by changing the oil, the plugs, air filter, gas filter etc. The engine worked a dream. Then I mowed most of the garden but decided to stop for the day . The next day I started it again and this time the machine shook badly when I engaged the mower so that i could nor mow. Then I removed and checked the mower unit. All looked fine except that the primary belt had a crack in it - was held together on the wide section only. So i exchanged the belt. On restarting and engaging the mower it was the same as befor - strong shaking. The only other problem that I can detect is that the belt keeper (L) and the belt guide (M) are missing. Could not get replacement yet> Can that be the reason?
