Hello im from Ohio  A friend has upgraded to a new exmark and he is selling his that he had bought used for himself.  Its a 1998 lazer z commercial zero turn 52 deck i believe its an x series. Model number says its a 1998 and had a kohler 18 hp but the previous owner put a 25 hp kohler motor in it my friend used it for a few years before it  started backfiring so my friend had the mower put in the shop to totally be gone over before he decided to upgrade. The mower had a valve job rebuilt carb updated coil system a new clutch, new belts, fluids change,fuel and hydraulic filter. Also replaced the head gaskets the mechanic said the engine looks real good inside. Also two new deck spindles and also new bearings for all three spindles mechanic said the hydros and pumps are in good shape. It will also come with a bagger system thats showing some wear. He is asking 2500.00    The age of the mower worries me (1998)  one big break down will put me way over what the mowers worth?   I could used an experienced opinion can anyone advise? I have a small yard, half acre i would like to have a heavy duty mower for in the fall because my leaves are unreal in the fall i have alot of trees.
