alankesaussie
I have a 16HP Kohler command on a ride on mower it's fitted with an LMK Walbro carb. Won't start without starting fluid. Runs like a clock on its own after a quick squirt of starting fluid.
Here are the facts! Has good compression, Has good strong consistent spark "Tested with 2 forms of spark tester", Has not sheared or moved the crank key, Has had new impulse fuel pump fitted and tested OK, Fuel shut off solenoid removed, Carb removed twice and totally cleaned thoroughly including idle circuit behind welsh plug, replaced steel fuel crossover line which was rusted inside and out all new rubber fuel lines replaced, New spark plug fitted, Battery at full charged volts and cranking speed is good, there was a lot of play in the throttle shaft which I have since re-bushed I manufactured some in my lathe, Fuel is fresh, Carb float appears to be OK, Float needle appears OK,
I am fresh out of diagnostic ideas. Regards Alan
Profanity was surely invented for those working on small engines![]()
