Headlights won't turn on Craftsman LT1500
tylerswire
Model 247.288812 > the lights are supposed come ON when the tractor's engine is running & turn OFF when the ignition key is moved to the STOP position. Mine don't turn on. The fuse & blubs are good. Looking for recommendations. Thanks.
Check to see if you have power on the A terminal of the ignition switch. No power bad switch.
