head torque & tightening sequence
maxamoo
does anyone know head torque and tightening sequence on B&S 445677-2188G5? I have looked for 2 days and even called Briggs.
300 in/lb Torque sequence is center top to bottom right to top left to center right and then bottom left. And double check that model number Is is possibly 445677-4188-g5 Since the number you listed doesn't appear to be a valid type number.
Listed on PD also in the parts diagram section, but maybe not updated on the power portal yet. I have found a few cases where the parts where not on the dealer sites that were used on JD
I don't normally the eparts section as I like to download the IPLs while working on an engine. But I do have access to PD myself just didn't look there.
