brinkkl2000
- Sep 23, 2015
- 11
- 26
I have a Cub Cadet with a Kohler CH18 engine. Sometimes I can hear the solenoid clicking but the engine wont turn over. If I hit the key 4 or 5 times it will come to life, starts and runs fine. I have a fresh battery, shows 12.8V at the B+ post on the solenoid, when I hit the key I am showing around 7V at the solenoid (spade post). I have pulled all positive and negative connections and cleaned them up. Pulled the starter and bench tested it, so far it has never failed, both by direct contact with starter and running a jumper wire from the solenoid. Could I just have a dead spot in the starter? I don't think it is a key switch as the voltage is coming through to the solenoid. I think it is 1 of 3 things, starter motor, solenoid, or switch. Don't want to dump a ton of money into chasing the offending part as I am getting ready to sell it.
