greynold99
Hi all,
I have a 1996 Cub Cadet HD2135 with a Kohler 12.5 HP engine. This Cub has the hydrostatic transmission. While mowing yesterday, after an hour and half, it started acting like it was running out of gas - the engine started hesitating like just before it stalls out but I was able to make it back to my garage. I shut it off and filled it up, but when I went to re-start - I got nothing. Thought it might've been overheated so I waited a while. Then when I turned the key, I noticed that not only did the key not engage the starter where it usually does, so I kept turning the key and did finally get it the starter to engage and the engine to start - although it was running very roughly. When I disengaged the choke, it immediately died. I was able to get it re-started a second time but had to keep engaging/disengaging the choke to keep it running...
I'm suspicious of the ignition switch, since everything was running fine up until I went to re-start and then I noticed that I had to turn the key an additional quarter-turn from where I normally felt the ignition switch engage the starter.
Was hoping someone would have some ideas on this and how bad/how much cost to swap out the ignition key switch - OR, if I'm completely barking up the wrong tree.
thanks,
greynold99
thanks,
greynold99
