Have a HRX2173HYA and need to replace the change cable.
dltech
  • / Have a HRX2173HYA and need to replace the change cable.
looks like I'll need to drop the rear drive mechanism to get access to the cable attach. am I missing something?
robert@honda
Drain fuel & oil.
Invert mower, clamp handlebar into a bench vise.
Remove variable mowing system shutter (see pics)
Remove rear scroll (see pics)
Disconnect cable from change lever.
Disconnect cable from clutch lever. Loosen lock nuts holding cable.
Insert pry bar into hold in transmission cable bracket, pivot transmission to remove belt from transmission.(see pics).
Disconnect drive belt tension spring, pivot transmission to access other end of change cable.
