Has anyone seen one of these?
Wendysguy
Hi All
I just picked up a 1975 Simplicity sovereign. It has a 16 hp Tecumseh Horizontal shaft engine in it. Has anyone ever heard of such a thing? I know that it is an odd ball set-up. I am just wondering if I am the one who has a set up like this.
Wendysguy
What size Tecumseh engine does it have?
That set was used for many years by all the manufacturers. They changed over to vertical shaft engines when they became more popular and decided they want to enclose the engines. Nothing new or odd about it.
Wendysguy
I see , so these tractors came threw with both Briggs + Stratton and Tecumseh engines in them.
Briggs, Tecumseh, Kohler, Onan, were used by the major manufacturers.
HarryHarley
It's odd in that it has a left side discharge??
Wendysguy
I took a couple of pix of the engine to show the exhaust set-up. It's the way that I got it , no modifications from me. When I picked it up the guy said that the engine was not original. It was only bolted down to the frame with 2 bolts and a 2x4 wooden shim. Fiberglass driveshaft plate was wiped out. all fixed now.
1955 Allis "B"
1972 landlord 10 h/p
1977 system 7016 16 h/p
earthworm
Is this an early OHV engine ?
I think the vertical shaft is more efficient, but the belts are more difficult to access.
Wendysguy
Yes it is. It's an OH160 XL engine. Basically it's an OHV 16 h/p Extra Life engine. I tried to find the year of manufacture and hit a dead end.
