So, I inherited a Honda Harmony 215 when I bought my house and the owner said that he couldn't get it running. Thanks to a few tips I found on here yesterday, I determined that it was the carburetor. I'm new to small engine repair, but determined. :wink: I dug in and found some junk in the carburetor. I learned that the carb float actually has to float, too! I installed the carburetor and refilled the tank and noticed gas pouring out. Took me a while to figure out what the problem was. After making sure the float was installed correctly (I think, more in a bit) I was able to start the mower, but only with the air filter off and the engine completely choked. Even then, the mower engine was not running very strong. I mowed my entire yard (fairly small) with the mower in this condition and the mower left some grass on the lawn like it wasn't strong enough to push the grass into the grass catcher on the back of the mower. My lawn is fairly short; I think I was only removing an inch or less of grass.
I'm wondering which direction to go at this point. Should I mess with the carburetor more? Is the float still installed correctly? Is it the spark plug not supplying an adequate spark?
