Harmony 1011 drive belt
Itsneddy
I was mowing a little to tight to a tre and got stuck on a root. When I finally freed the mower, the transmission stopped working. There was a bit of white smoke and it moved, but barely. A minute or two later, it stopped rolling entirely. None of the gears would engage. Is it the drive belt or did I cook the transmission?
Most likely you just burn the belt to the point that it will no longer work. Replacement needed.
