I have an Lt1000 that is hard to start. It is several years old and has alot of hours on the engine. The engine is a 17.5 hp Briggs. It doesn't leak or burn any oil and I change it about 4 times a year because I am cutting my yard (3 acres) and mama's yard (5 acres) and picking up leaves every year so this thing gets a good workout. Once you get it cranked it runs perfect just getting it cranked is the hard part. I have to put a charger on it and run the volts up to around 15.5 just to try and get it to turn over past the compression stroke. I have checked all the cables, swapped starters and checked all I know to check. It acts like it doesn't have the power to turn the engine over once it hits the compression stroke. I adjusted the valves about 3 yrs. ago but haven't really had any problems till last year. The battery has a full charge and I still have to hook the charger to it. Even when it is hot it acts like this. I'm wondering if the valves are to tight and it has too much compression. If someone can point me in the right direction it sure would be appreciated. Sorry this is long but trying to cover everything.
Thanks, Mike
Thanks, Mike
