SidecarFlip
- Aug 21, 2018
- 4
- 282
Far as the tapping goes. mine 'taps' too until I increase the RPM and then the ACR deactivates and it's quiet as a mouse. The tapping is the ACR sub cam attempting to hold the valve (intake or exhaust) off the seat by a few thousands and if it taps, it's working fine so you have a valve clearance issue (excessive). The ACR cannot hold the valve off the seat if the clearance is too great.. That is why you have a hot start issue. Lots of compression and quick ignition but no ACR so the motor cannot get past TDC and roll over.
If you feel incapable of removing the valves, any competent shop can handle it.
If you do it yourself, I'd de-carbonize the head (which Kohler recommends anyway every 500 hours) and check the valve seats while you have the valves out. Seats and valves are easy to lap when it's apart.
Make sure you install new head bolts and a head gasket. Head bolts are much cheaper at Fasten-All versus the mower shop. Head gaskets are online at Amazon.
