KC_kid
- Apr 17, 2014
- 2
- 29
Mouse nest blocking air flow.
I'm wondering if I find this under the cover somewhere. Looks clean at a glance, but I haven't removed cover yet.
No, I have not. I will make sure and do that when I'm working on it. Clean muffler, replace electrical, double check clean cooling fins, check RPMs and throttle linkage. Might get a new air filter although I hate to replace a filter I am 90% sure is clean. I know carb, oil and gas are clean. Engine acted exact same with 2 separate clean carbs and fresh oil. Running 89 octane gas.
To me, this is mind boggling:
Engine starts easy and runs good, until it slowly dies after decent use and you find it is overheated.
Or, it mows your whole yard perfect and when done, you find it's overheated.
Have you adjusted valves? Exhaust valve could be we bit to tight
