Kcsguide
- May 16, 2014
- 3
- 21
Ida-Boy, I have the same mower and it is doing the exact same thing. I replaced the oil seal at the top of the shaft and it didn't fix a thing. The problem is that by the time you remove everything, including the flywheel to get to where you could see where it's coming from, the evidence is gone. I see one hole under the coil that is not threaded and I am wondering if that is some kind of pressure relief port that sticks open when it heats up??? Anyone know anything about that??
