gxv 140-135 cm3 , leaks oil
cruizertoo
My hr 215 sx, gxv 140-135 was leaking oil from the bottom of the crank shaft, I removed the old seal, went to the local mower repair shop and bought part # 91201-zg9-u71 and was told that was the replacement seal even though it was thicker than the old seal, I destroyed the new seal trying to seat it, the old seal is not even as thick as a dime, where the new one is about a 1/4 inch thick. What is the right part # and how do you seat it? any information will be greatly appreciated.
Hello,
I got the lower oil seal from PartsTree.com . Your part number (91201-zg9-u71) is the same part number on PartsTree.
It does say that that this part replaces 91252-888-003 .
Mine installed with surprisingly light finger pressure, I didn't have to drive it in with a socket. But no leaks so far.
Regards
Jeff
Hello,
Regards
Jeff
Jeff, did you put the flat side of the seal to go into the engine?
