gx75 front end
okfine
Hi I am trying to find out if there is an adjustment for tow in or out on the gx75. It looks like one of the front wheels is turning out. I don't know if that makes any sense or not. I do not see any type of adjustment. Any suggestions?
Thanks
Thanks
If you don't see a adjustment you may have a bent wheel shaft or rod link.
Thanks
Hi
Looking at my X140 also no adjustment. but the two ti-rods could be removed and bend in a vice to obtain the correct distance that will rectify tow-in or out.
Regards
PJ
I have a GX75 & my JD repair manual shows no adjustment. Check your tie rods to see if they are bent, if not check the spindle.
Thanks I will work on this in the next couple of days. Thanks for all the help
