abarone300
- May 8, 2018
- 44
Hello guys, I'm trying to remove the flywheel, because I suspect something may be wrong with the key. My motor won't start (it turns over though). Somebody suggested il might be out of timing, and to check the key; sometime the timing goes out of wack because of a broken key (checked fuel delivery and spark; both ok!)
This morning I proceeded and attempted to remove the flywheel, but could'nt (removed the center nut) and tried to use the extractor; nothing, the flywheel doesn't budge. I noticed two things: 1) I don't see the square key in the keyway (normally it protrudes 1/8" out, I see just a wedge shaped object a 1/4" in the keyway, 2) I also wanted to ask if the three philip head screws screwed in the flywheel ( to the side/distanced equally around the flywheel) might be the reason I can't pull the flywheel out, are the three screws there for a reason, are they in fact holding the flywheel secured to crank shaft, or serve for an additional way to balance the flywheel? Thanks
