Gx 100 engine governor
mark60
Honda gx 100 engine governor arm moving when just pulling engine over not running
Do you mean the governor arm is bouncing when you are cranking the engine or doing something else.
mark60
When cranking.the guy had the gov arm off to replace the carb. Eng is a gx 100 1219275
