I'm having issues getting my mower to start. It has the Kohler Courage 27 engine. I recently fixed a leaky valve cover gasket. The first time starting it after the basket repair it was hesitant to start, so I jumped it with my truck and it started right up. I let it sit and run for half an hour, but it hasn't even cranked ever since then. I go to start it and it just clicks. I've charged the battery, bought a new battery, and replaced the solenoid, but it still just clicks. I took off the starter and jumped it with a battery and it spins with no issues. I put the starter back on and it cranked for half a second, but then stopped and right back to the click. I tested the voltage to the starter and with the starter cable removed I get 12v, but when I attached the cable to the starter I only get 3v. I took out both spark plugs and the engine would finally crank, but when I put the spark plugs back in, right back to the click. At this point I'm a bit stumped. Any thoughts?
