Gts5 gas tank needed
KeithGill
Looking for a new/used gas tank for my toro gts5.
Mine is cracked at mounts and leaks.
Thanks
thanks but i have since learnerd i need a specific tank for my specific engine. A Suzuki. go figure.
If you can't find a used one. Try looking at the newer commercial toro proline tanks and mounting hardware the deck style is the same and the larger tank might be nice. They both feed the carb the same amount and are gravity fed
