Export thread
GT235 electric clutch
#1
E
esirons
How do you remove electric clutch from GT235 with 18hp Kawasaki?
#2
Retiredcarguy
Retiredcarguy
What year GT235 do you have? As I have a printed technical service/repair manual.
I'll be glad to scan the related clutch page(s) for you. Let me know.
#3
E
esirons
2003 GT235 w/Kawasaki engine
#4
Retiredcarguy
Retiredcarguy
Good luck. Let us know the outcome.
#5
E
esirons
Clutch off, new pan gasket and seals installed. End up using a gear puller do to rust on shaft.
Thanks
#6
Retiredcarguy
Retiredcarguy
Thanks
Glad that it is finished. JD said in the manual that the clutch would "fall" off of the shaft. Oh, well, so much for the previously applied lubrication.
Hope that your Deere is now running fine!
