GT235 electric clutch
What year GT235 do you have? As I have a printed technical service/repair manual.
I'll be glad to scan the related clutch page(s) for you. Let me know.
Clutch off, new pan gasket and seals installed. End up using a gear puller do to rust on shaft.
Thanks
Glad that it is finished. JD said in the manual that the clutch would "fall" off of the shaft. Oh, well, so much for the previously applied lubrication.
Hope that your Deere is now running fine!
