B beretta22 Well-Known Member Joined Aug 25, 2022 Messages 119 Nov 29, 2024 #1 Need help installing a headlight assembly. How to install/reinstall the hood? Is it better to remove the front grill first? Is there a service manual available ? Last edited: Nov 29, 2024
B beretta22 Well-Known Member Joined Aug 25, 2022 Messages 119 Nov 29, 2024 #2 This is the part assembly. Attachments IMG_0328.png 629.6 KB · Views: 11
StarTech Lawn Royalty Community Leader Joined Feb 19, 2020 Messages 14,553 Location Pluto Nov 30, 2024 #3 Cub is leaving that for you to figure out on your own. The service doesn't cover that area. Download Cub Cadet 3000 Series Service Manual | ManualsLib www.manualslib.com But does appears that you just open the upper hood and remove two screws. Last edited: Nov 30, 2024
B beretta22 Well-Known Member Joined Aug 25, 2022 Messages 119 Mar 12, 2025 #5 Can’t download.Image is to large..Can someone tell me if the plastic headlight assembly is attaches to the top of the hood bracket, or, the bottom Last edited: Mar 12, 2025
