GT 2550 Reverse Problem
tactical
My GT 2550 has been great but is getting harder and harder to move in reverse. When new, 14 years ago, it was slow but now it crawls. I've changed the Hydro-oil on a regular basis and it still creeps. I read somewhere that the Hydro pump was the weak point of this mower, is that true? Is there a fix other than changing it out?
Hydro Gear makes a rebuild kit, I'll give it a 50% chance of working, when you get inside if the piston bores are scored it probably won't work.
If it were me I would take pump apart first and give it a good look before buying rebuild kit.
