Perry J
- Aug 26, 2023
- 1
- 3
GT 2000
Last week I had to activate and deactivate the 'PTO on' lever a little bit while using the key in 'start' to get it to turn over. No response with just the key.
But now it just clicks intermittently when I jiggle activate the PTO switch, no turn over, no start.
Battery, solenoid, and the starter seem good in that when I jumper the trigger contact on the solenoid to the battery (with the key on,) the engine will turn over relentless but not fire over.
Gas tank is full.
I think this may narrow it down to either an ignition switch issue or a PTO switch safety issue. Suggestions?
Nameplates attached
Gas tank is full.
Nameplates attached
