Grease used on spindles?
Bobby Boyd
What type of grease do you guys use on the spindles?
-bobby
Bobby Boyd
Well...I called and spoke with the scag dealer where I bought my turf tiger. The mechanic said Lucas red and tacky was the best to use. I called a couple of other scag dealers nearby and one said a black molly (they didn't know the brand they were using :( while the other said mystic j6 (not sure of the j6 but something like that).
All three stated they used the same grease for all zerk fittings.
-bobby
Boudreaux
The Scag Manual indicates White Lithium grease for the Spindles. I looked high and low, but failed to find that in a tube.
SO. I went with Mystic JT6 High Heat- EP2 Lithium Complex (a red grease)
Any good high temp grease will work just fine, as long as you preform maintainance according to schedule.
