Gravley Blade Offset
lil SIG
Looking for good HIGH LIFT Blades with the proper offset for Gravely ZX-60.
THANKS
Looks like you need Gravely 09081200 blades which can be Rotary 13624 or Stens 320-704 but to be sure post the six digit model number.
MParr
@StarTech is spot on. I find that the Rotary 13624 better than the Gravely blades. I run a Gravely Pro Turn 260 and have tried several brands and styles. Here's something that I've found that works really good. Get you a set of Rotary 6083. Also, get you a set of 1/4" blade spacers. The blade spacers compensate for the offset. Put the blade spacers between the blades and the spindles. This will really sling the clippings.
