Gravely ZTR 60
Tiger Small Engine
You are correct I do not know how to perform the check of the electric clutch, I cannot afford to take it back to the gravely shop, they have drained me of all the funds available. Carburetor, fuel pump, ignition coils, replace fuel lines, complete tune up. Now remove the gas tank and clean it out. I’m not able to transport it to the shop that cost is $100.00 one way. I will be on my third trip, that cost could buy another $295 clutch.
The reason I said I would replace the clutch I can get the clutch from another Gravely with a FR730V Kawasaki engine and install it on mine, that engine blew up because the plug touched the piston and burnt a hole in it.
I guess you can tell I’m a gravely die hard, I grew up in the 40s and gravely was the best you could buy. Thangs change.
That engine with piston in it can be rebuilt (you probably know this). Gravely is not a big player in my area, however, they are fine mowers.
