Topgun1739
- Jun 10, 2019
- 1
- 3
MACHINE: Gravely ZT50 [mdl. 915144]
PROBLEM: Will not start with normal procedure. Jumping from the battery to the starter starts the engine and it runs normally, but disengaging the hand brake or engaging the blade PTO kills the engine. Seat safety switch, hand brake switch and PTO switch have been removed and tested independently - all function as they should.
QUESTION: Could the problem be with the Start Relay, Key Switch or Starter Solenoid? If so, how do I test them?
Any suggestions or recommendations would be greatly appreciated.
